Actually removed one of the parameter in search tool how can I add those parameters.
Hi Senthil,Can you update us you are facing issue with which software like Promis.e, Substation or BRCM. Also if you could provide steps followed along with screens shots will be helpful for us to understand the issue.Regards,Satish Saptasagar
In Promise,
Here I removed the mode of drawing from search tool now I want to add into again search tool so what is the process to add this.
Hi Senthil,Can you try renaming the Promis.e Per User Application Data folder and then check if you are able to see the search tool again. You can refer the below Wiki Link for the path where the Promis.e Per User Application Data folder is located.Regards,Satish Saptasagar
Answer Verified By: Sarvesh Kulkarni
Thanks. issue resolved. Instead of deleting or renaming the profile Bentley can give the option for customizing the search tab it would help end users .
