Hi All,
If you open a drawing that has been created in AutoCAD (DWG), that has viewports, how do change (move) the cutting plane?
In AutoCAD you enter the windows and then with the 3dclip command you move the planes up and down.
What is the alternative to this command in BRCM/Microstation?
We recieve a lot of drawings like that and often it is necessary to adjust the windows.
Thanks in advance
-Philipp
Hi Philipp, There is options of Creating viewport in Microstation but we need to know that whether you are creating view port of AutoCAD (.Dwg) model or of Microstation Model(.dgn)?
There is option of Cutting planes in BRCM viewport but we are not sure the AutoCAD Model in BRCM can be adjusted like so .If possible can you share any one of Auto cad Model ?Regards,Avanti
The Viewport is created in the AutoCAD .DWG file.
Because that is the way we get the drawings delivered.
And we are looking for any way to adjust the plane withing BRCM, I try to find a shareable file.
