How to run 2 brcm ?
Hello Long Jun Deng,You can run one instance BRCM at a time.Can you let us know the reason why you need to have two instances of BRCM running at a time?
Regard,Avanti Khandalkar
HI Dear friend,
Thanks for your reply.
I make the equipment and cabletray in 2 different files and i want to open these 2 file the same time.
Hi Dear friend,
Because i make 2 files and hope to open them the same time.
Hi Long,If you are placing Raceway you need to reference equipment file in raceway or cable tray .dgn and vice versa. Its not possible to open 2 different file in one Instance of Software.Regards,Avanti Khandalkar
So i have to open the file one after one?
if there are 2 or more projects, this is cost to much time...
