I need help about this errorError[0]: SYS mismatch CP/CP count: component ID = 2
Hello Milthon,
Thanks for your question. Could you please provide me application details?
Also please refer following communities link addressing similar concern.
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/27559/error-0-sys-mismatch-cp-cp-count-component-id-1-in-openplant-isometrics-manager
Hope this helps. Looking forward to you reply.
Vidit Ruhela
Hi Vidit, thanks for you answer, my AutoPlant Modeler version is: (SELECTseries 7) Version 8.11.12.235 and Class editor is: V8i [08.03.01.06]
Thank you for the update, did you check with steps provided in above given Wiki Article? please check with same and update us if provided steps able to rectify your issue.
regards,
Hello Vidit
Of course I did, but since the problem I have is even more complex, I'll tell you more in detail:, I am trying to generate some isometrics with a specification that I create for a project with Victaulic elements and the error specifically occurs when extracting a Y-Strainer, I followed some instructions that were in another forum: (
I made the changes that they indicated to me and then I threw another error that was the one that I made mension.
When I initially generated the isometrics via OPIM, this error appeared:
Then I followed the instructions in this forum:
After having followed these steps I get the other error that I coment to you:
