BRCM TEE CONNECTION BETWEEN TRENCHES OF DIFFERENT DIMENSIONS
I am using BRCM CONNECT for a new project I'm working on, and I have a situation where the main trench in the switchyard branches off into a smaller trench leading to the equipment. The main trench has internal dimensions of 1000mm x 1000mm and the smaller trench, internal dimensions which are 750mm x 750mm needs to connect to the main trench via a tee connection.
Ideally, I would like to have a tee connection branching off the main (larger) trench with dimensions that match the smaller trench so the overall trench will appear more realistic.
Any suggestions on how I should go about this?
Thank you.
