We recently upgraded our AutoPlant Modeler (8.11.14.124) and OPIM (08.11.11.294) we are trying to export a pcf file (we have in past versions) but now I don't see that option. Is that correct, or do I need to change a setting? If it was removed, why?
Hello Ashley,
Yes separate PCF generation option was removed from AutoPLANT, because OPIM application is always generating PCFs and then building isometrics model. If you have requirement to generate PCF of required components, then you can manually select required components and generate isometrics.
PCF will be created automatically and saved on Isometrics Working directory.
Best Regards,Kestutis Mitkus
Product Engineer – Bentley Systems
Hi @Kestutis,
I'm looking to connect with someone from Bentley who can support a request from a mutual major account customer who wants to convert Revit piping models into AutoPlant through writing a PCF file. Could you suggest someone with whom I could discuss this further? I'm based in the UK.
Regards, Simon (Consulting Services Manager, Autodesk)
