I'm currently using OPM and OPIM SS6. For some reason I get duplicate isometric error message in OPIM and I'm not able to run isometric for this line. I have only on sheet at Isosheet Manager and I have tried to autogenerate Isosheet and republish all I-models. Still there is one duplicate isometric for this line?
Hi Tuomas,
Thank you for posting your query in Bentley Plant Forum. We suspect that there is already an isometric present in output location. However, you can try following options in OpenPlant Isometrics Manager which will overwrite the existing isometric and create a new one.
Hope this helps.
Swapnil Joshi
Hello Tuomas,
This is also happening when you reference DGN file and the isosheet name contains the same pipeline.
HTH,
Rahul Kumar
in OPIM settings are both True
In OPM Pipeline manager there is only one pipeline
But when I load I-model to the OPIM there is two pipelines
What could cause this?
Please remove reference file if you have. If there is still any issue, then I would like to request, check Item tree browser and check inside the pipeline whether there are some orphan sheet attached.
This some times happens, when you move a pipeline from Pipeline Manager and assign a new pipeline to it and sheet remained inside the particular pipeline.
Please try above case and update us. Thanks!
Hello Rahul,
thank you for your help and advises. I found out that there is one single isometric without components in Item Browser, how can I delete that one?
BR
Tuomas
