HI ,WE are trying to get global co-ordinate in isometric instead N-S-W-E, which always shows positive values by changing N-S-W-E,Is there away to get gloabl cordinates with negative or positive value as X and Y, instead of N-S-W-E,
Vivek
Hello Vivek,
Thank you for writing on Bentley Communities. We would like to recommend you the following article which will give you a brief idea about the isometric coordinates-
We hope this helps. Do update us for the same.
Devendra Warke
Bentley Systems
Thanks Devendra,
But what we are trying to achieve is attached here,
Regards,Vivek
We appreciate you for having a quick call with us. On the call we were able to understand your requirements. We will explore the possibilities for isometrics to display coordinates as X,Y,Z rather than the directions N,S,W,E.
We will update you at the earliest.
You can achieve desired result by making changes in Isometric Configuration.
Hope this helps. Looking forward to you reply.
Abhijit Bute
Hi Abhijit,
That dialogue box wouldn’t help us, the result we are trying to achieve is replicating [x,y,z] from model environment to [x,y,RL] in Isometric, now in model X,Y,Z always remain X,Y,Z and negative/positives signs applies to co-ordinate values.
We need similar result in isometric as well, coordinate values should change sign and not the X,Y,Z. Currently In isometric co-ordinates always remain positive and North becomes south if pipeline crosses global origin, we are looking for a solution where Y axis remain Y and coordinate changes sign. Regards,Vivek
