HI,
If I try to open DWG file in BRCM, I receive information "file.dwg is not in a recognized file format". The same problem occurs when I open the DGN-file and attempt to attach a reference DWG-file. This file is not open and in the Message Center I receive info as below "... is not in a recognized file format".
If somebody had the same problem and know how fix it.
I will be grateful for help.
Best regards
Waldemar
Hi Waldemar,We would like to know that if you are facing this issue with referencing the DWG file in BRCM DGN file for a particular DGN page or a Project or its happening in all the projects.Also can you let us know DWG file was created using AutoCAD and which version of the software.The above details will help us better understand the issue you are facing.Regards,Satish Saptasagar
