I experience such error when installing Autoplant Prerequisite CE package, because of this error AutoPLANT modeler v8i SS8 CE won't be able to install afterwards and always ask me to reinstall prerequisite package. please help
Thank you!
PDF
Hello Jeffrey,
Thank you for posting your query on Bentley Communities. We would like to tell you that V8i and CE (Connect Edition) are two different generations of AutoPLANT Modeler.
If you are Installing AutoPLANT Prerequisites from the CE package then you should use the AutoPLANT Modeler installable from CE package (and not from the V8i one).
We recommend you to follow the below mentioned procedure for AutoPLANT CONNECT Installation:-
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/42540/autoplant-modeler-connect-edition---installation-procedure
NOTE:-
It is required to install the AutoPLANT Prerequisites and Modeler using "Run as Administrator" command.
Do let us know whether you were able to resolve your concern or not.
Devendra Warke
Bentley Systems
There could be few reasons, why this is error is coming. Can you share your contact details so that we can discuss this briefly.
Thank you for having a live meeting with us. As we have recommended you can go through the Windows Updation and then follow the procedure mentioned in the below link:-
Do update us about this concern.
