How to measure distance between pipe, or distance from any OPM entity to other object?
Based on not being able to snap to OPM entities, and not being able to drop these objects..
Referenceing
https://communities.bentley.com/products/electrical___instrumentation/f/elcocad-promis-e-forum/125861/snap-to-quardrants-of-a-pipe
and
https://communities.bentley.com/products/electrical___instrumentation/f/elcocad-promis-e-forum/182513/opm-ce-drop-element
Hello Peter,
Thanks for your query,
We tried the same at our end & can snap center line without any issue. Refer image below.
On the same thread we will reach you to have details on this.
ThanksRegards | Deepak Singh
Sure we can snap to connection points. The issue is being able to snap to other parts of Bmech geometry. As an example measure distance between pipes, from bottom of pipe to steel, or other. Basically having a flexible way of snapping to geometry other than connection points is wanted.
Holding down the Shift Key while using AccuSnap will enable You to Snap in 'normal' way.
