I'm new using Instrument and Wiring tool, in the company we have the autoplan suite with the following applications:
- Autoplan Modeler
- Data manager.
- Document Manager
- Instrumentation & Wiring
- Vision
I need to associate a P&ID number, and a line number or equipment number to each instrument, however i can't find a way to achieve this... i try to create a dump P&ID document in the document manager and create a line number in data manager, but i can't associate these with the instrument.
Jhonatan
Hello Jhonatan,
Thank you for posting your query on Bentley Communities.
Can you please elaborate your concern so that we can suggest you the suitable answer. Also it would be great if you can share your contact details so that we can quickly resolve this concern of yours.
Devendra Warke
Bentley Systems
Hi Davendra,
In the Company we are committed to use the Autoplan suite for improve productivity. I belong to the Automation and Instruments department and initially our objective is to make an instruments list with the following fields (with others not shown):
By now we’ll not use Autoplant P&ID or Autoplant modeler, we just want introduce the information manually in the database to generate some deliverables, however I found difficult to associate the highlighted fields for each instrument, I create the lines and equipment numbers (or tags) using the data manager and some P&ID documents in the document manager but I can’t link these with the respective instrument to signify that the instrument will be installed in that line or that equipment and belong to that P&ID.
