Being in need of creating a new custom valve, we followed how-to-add-custom-valves-in-schema and how-to-create-custom-components-from-cell
A new catalogue was created in catalogue editor, creting a VALVE section.
Manually added and removed fields, as we felt appropriate.
For some reason we get :
Which looks ok.. however we also get
What can we be doing wrong?
Hello Peter,
Constraints shows based on properties available to the class, if class doesn't has any properties into it then no constraints can be seen as well. For testing this issue in detail, we would request you to please log a SR for this issue.
ThanksRegards | Deepak Singh
Saving, exiting and restarting SpecGen / catalogue editor a few times, solved the issue.
Nothing was wrong with .mdb file
Thanks for the confirmation.
