Hi folks,
I was referring this below WIKI link which is similar to my requirement but I need to govern through Spec by using Spec data.
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/28661/how-to-create-four-ports-component-with-different-sizes-in-openplant-modeler
In this WIKI we have created a new Port "BRANCH_PORT1" on REDUCING_PIPE_CROSS.
How can I use my Spec Data to map it through Spec?
Current Scenerio:
System is automatically taking BRANCH_PORT1 value as 8, Can anybody have an answer?
Regards | Abhilash Panchal
Hello Abhilash,
Thank you for posting your question. Please allow us some time to check for your requirement and we will get back to you with possible suggestion regarding your concern.
Regards,Vidit Ruhela
Thanks for posting your query.
Is there any value defined in IIF statement for property name?
Please check if some default value custom attribute has assigned to newly added port property.
Regards | Deepak Singh
Here you go!
This is the setting.
Thanks for the snap.
I would request you to please log service request so that we can investigate this issue at our end by setting up your schemas.
