And administrators too?
Hello Neil,
Thanks for posting your query on Plant Forum.
Yes, both applications can be run on the same machine. There is no any conflicting stuff to override setup related to each other. Both versions are different one with different folder structures so to same machine both setups can be run simultaneously.
Regards | Deepak Singh
Answer Verified By: Rahul Kumar
thank you Deepak
