someone already post this info but in my case, its not working.
Classes > Plant base Object > named Item > Document > P&ID Document > Properties Tab.For each property, you have to adjust or add a priority value.The higher the priority value, the further up the list it will be shown.The lower the priority, the further down the list it will be shown.
Can someone explain how the "Category" supplemental... Priority works?
Hello Leslie,
Depending on which version of OpenPlant PID you are running, the Property Priority is set on the Property Name or by adding Property Priority Custom Attribute.
Assuming you are running a later version of OpenPlant PID, the Property "priority" is set on the property name itself - see below.
When no value is entered, the list order is fairly random. If a value exist, the higher the numeric value, the higher in the Category the property will appear. I suggest you start numbering your desired "top of category" properties, at around 500. Then down from there. I also recommend you leave a space between numbers. First property set to 500, next lower property set to 495, etc. This allows you to insert other properties in between if necessary.
The Category custom also has a Priority, and this is used to set the order of the Categories in the Properties panel. Keep in mind that this can be easily overridden by the user. They can drag the categories as they need and then perform a Save Settings in OpenPlant PID and override that setting.
Another important characteristic of the Category custom attribute is naming and what is entered in each of its fields. When adding the Category custom attribute manually, make sure you fill in each field with the exact value as already defined in the out of the box Category. One little difference, and it can result in a new category being created.
I suggest that when reusing an existing category on a new or existing property, copy it from an existing property to the new one. This can be accomplished as follows.
In the Class Editor:
This will copy the custom attribute to the property and maintain the field values.
Breaking down the Category custom attribute.
Standard: Not used. Leave blank or enter 0.
Name: The name of the Category (Cannot have spaces in the name)
Display Label: The name as it is displayed in OpenPlant PID (This CAN contain spaces in the name.)
Description: Optional. A description of the Category.
Priority: Defines the position and order of the Category in the property pane.
Expand: Display the Category expanded or collapsed on startup.
I hope this helps,
Tony DeRosa
Senior Application Engineer
Bentley Plant
So on….
Hello Lee,
DO NOT change the priority on the CATEGORY. The properties are what you are trying to "order". As you have done, change the PRIORITY on the PROPERTY only.
If i get a chance today, I will create a video and post it.
Thanks again Tony.
I redo what you just suggested, by removing the Category Priority to 1 since I cannot leave it blank. Is that ok?
Let me try that now and let you know the outcome.
Cheers Mate!
I tried it with 1 as Category Priority. No changes. Can we do skype call perhaps you can see the problem occurs?
