Our organization is planning to move all DGN file operations from International Feet to U.S. Survey Feet. Design file settings will change as shown:
Master units: FEET ---> U.S. SURVEY FEETSub-Units: INCHES ---> U.S. SURVEY INCHESResolution: 12000 PU/FOOT ---> 12000 PU/U.S. SURVEY FOOT
We will have to convert our customized files and resources:-- Design files-- Cell libraries-- Seed files-- Border files (DGN)-- DgnLib's
As for the OpenPlant Modeler application:
1. Will the application work correctly with design files having Survey Feet working units and storage units.
2. Are there configuration files and resources that also have to be converted to U.S. Survey Feet? Are there variables or other settings that will need adjusting? Do we to adjust the application's:-- cell libraries-- dgnlib's-- seed files-- cfg files-- xml files-- macros-- databases
3. Anything else?
Hi Warren,
Could you confirm that do you want to migrate from the existing project to new project or the changes should be made into entirely new project??
Ashutosh Patil
Since we are owner-operator, all projects use the same workspace. We intend to modify that workspace to Survey Feet where necessary, start new project files entirely in Survey Feet, and convert existing project files entirely to Survey Feet. Note that working and storage units will be changed as mentioned above.
Warren J. MalveauSenior CADD Support SpecialistLos Angeles County Sanitation Districts
