How do I specify workset (and/or workspace) when starting OPIM? Following the help document below, the batch switch seems to be -wp but that doesn't work. I've tried -ww as well and that didn't work either. In V8i, I can use the -wp just fine.
https://docs.bentley.com/LiveContent/web/OpenPlant%20Isometrics%20Manager%20Help-v6/en/GUID-DFACEC10-39DC-4480-B7EE-F2FCDBD40186.html
Best regards,
Tuan Le
Hello Tuan,
Thank you for your concern. We will check your concern and get back to you at the earliest.
regards,
Vidit Ruhela
Did you try using wp<WorksetName>. It seems to be same as that of V8i.
ThanksRegards | Deepak Singh
Tuan Le said: -wp but that doesn't work
I did Deepak. tested batch code below:
"C:\Program Files\Bentley\OpenPlant CONNECT Edition\IsometricsManager\Bentley.Isometrics.App.exe" -wpOpenPlantMetric
Are you getting some error message upon running the syntax to cmd? Please share.
I further did the testing at my end & by using defined arguments able to load OpenPlant Isometrics Manager CONNECT Edition.
Please ensure that you have deleted preferences from "C:\Users\<User Name>\AppData\Roaming\Bentley\opim.
You need to add argument for workset and workspace as shown below.
Hope this helpRegards | Deepak Singh
