We would like to exclude Unit designators for Length and NPS. This regards exporting external reports, and Grid views
Example:
The following fields are exported with unit:
This applies to external Reports and Grid View
Hello Peter,
Thank you for your concern. We will check your concern and get back to you at the earliest.
regards,
Vidit Ruhela
To remove unit of measurement from any desired property, you need to define "Replace Calculated Field" from External Report Designer. As an example, please refer below replace expression that has been defined to remove the mm from Nominal Diameter property.
Once calculated filed is defined, we need to include that to Data Binding field to see correct result.
Save all the changes. Launch OpenPlant Modeler & from external reporting generate report to see the output.
Hope this help.
Regards | Deepak Singh
