Hi all
How to change the symbol in openplant isometric to make the difference between 3 Way Valve and 3 Way ball Valve.
Best Regards
Salim
Hello Salim,Thank you for posting your query on Bentley Communities. We would forward your query to the concerned personnel and will get back to you at the earliest.Regards,Devendra WarkeBentley Systems
Hi Salim,Please follow below steps to change in graphics between two similar valves.As the isometric is generated, click on 3 Way Valve.To view IE _symbol we need to follow below stepIsoextractor -->Showtag Data-->Show Component Tag and Click on Valve, Show Component Tag box appears.In it you can view the IE_Symbol. Suppose e.g for 3 Way Ball Valve its IE_SYMBOL = 3WABW for 3 Way ValveGo to respective project data set and then Isometric cell, Open the above cell 3WABW through Models copy it and paste it with new one and change the graphics. As we are done with changes in graphics we need to change for respective new 3 Way Ball Valve in Schemas as well.In Schemas (Select the 3d schema and supplement Isometric Extractor schema) go to valve -> Multi way Valve->3 Way Ball Valve --> you can view all three way valve list.Go to the 3 Way Ball Valve -> Select that valve and override it by right click on it Proceed to Isometric Component .In Isometric Component type in the Cell name -3WABWBV with the cell name and graphics you changed. And then again generate the Isometric with required 3 Way Valve and 3 way ball Valve.If you have more queries regarding this issue then kindly do let us know or you can raise the SR through below link .https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/38551/how-to-log-or-report-service-request-for-bentley-plant-productsRegardsAshutosh Patil.
Hi Ashutosh Patil
In Schemas i loaded OpenPlant_3D.01.07.ecschema and OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.07.ecschema
But THREE_WAY_BALL_VALVE his empty !
How to add what is missing ?
Best Regards, Salim
Hello Salim,We performed a quick test and we are getting the "Isometric Component" section which allows us to make the necessary modifications for changing the symbol for Three Way Valve.
We think that the OpenPlant_3D.01.07 ecschema has not been Supplemented with OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.07.ecschema on your system. Thereby you are not getting the section.Can you give it one more try and supplement it with OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.07.ecschema present in the default location :-
For Metric Project = C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace\Projects\OPModeler_Metric\DataSet\Schemas
Do update us with your findings.Regards,Devendra WarkeBentley Systems
Hello Devendra Warke,
iI did the test again and also in the Metric project. and Imperial projectin any cases it's empty!
