Hi, how to make a structural materials report? How to see in the Element information the weight, type and length off structural?Tks
Hi Nicolas,
Thank you for posting a query in Bentley Plant Forum. One can create material report of primary supports in OpenPlant Modeler from the External Reports option present in OpenPlant Modeler.
There is a plethora of Report types to select from and you should be able to create a report for primary supports.
However there is a special product called OpenPlant Support Engineering which allows you to place and create structural reports as you desire.
Hope this Helps!
Nicolas Marin said:How to see in the Element information the weight, type and length off structural?
Can be seen those properties, somehow?
I have V8i version.
