Need help working from home with your Bentley software? We're here to help - click here
AUTOPLANT Modeler: VIctaulic not connecting
In all attemps to join any Victaulic component to the second end of a Victaulic ELBOW, Autoplant fails to connect;
Here are the details...
1. Placement of AT_ELBOW90_LR100   SUCCESS
2.Placement of AT_IPS_PIPE to one end of the ELBOW90_LR100   SUCCESS
3.Placement of AT_IPS_PIPE (or whatever component) to other end of the ELBOW90_LR100  FAIL!!!
Autoplant says it cannot find a component compatible with the connecting port data, which are End Condition=IGM and Nominal Size=6.
But there is one, obviously because it succeeded in placing the first one.and I double checked in the spec anyways.
Note that AT_IPS_PIPE are the only component that you can connect on BOTH sides.
I checked in JONTS.INI and PORTS.INI files bit could not find anything irrelevant.
Thanks for helping !
