How can user open AutoPLANT Modeler model in Revit?
(AutoPLANT Modeler version is 08.11.13.253)
Thank you for posting your query on Bentley Communities. You can try importing/linking the CAD DWG file into Revit.Regards,Devendra WarkeBentley Systems
Hi Avi,
User can create an ACIS file from the model in AutoPLANT Modeler and then import the ACIS file from the Import option in Revit.
This is the simplest method to open/view AutoPLANT model in Revit.
