Does anyone know the best location to download all the imperial catalogs files (.mdb) for Openplant Connect - Update 5?
I am missing a few catalogs on my workstation.
looking for bonney forged, Dezurik, Fisher, Grayloc, etc.
thanks!
Hello Martin,Thank you for posting your query on Bentley Communities. We are forwarding your query to the concerned personnel. Meanwhile we would like to know that are you aware about the reason of not having these Catalogs in your system? Were they removed from the system?If you are in a position then you can try reinstalling the application so as to set it back to default with all default catalogs readily available with you.Regards,Devendra WarkeBentley Systems
Hey Devendra, see image below of the spec I see on my install.
I don't see bonney forged, dezurik, fisher, etc.
Hello Martin Mendez,
The folder you are showing is the directory of the SPECIFICATIONS. You need to look in C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\Workspaces\WorkSpace\Standards\OpenPlant\Catalogs\ - followed by Imperial, Metric, or MixedMetric folder to see the catalogs.
Here is a snapshot of the Imperial catalogs folder.
I hope this helps,
Tony DeRosa
Senior Application Engineer
Bentley Plant
