Dear All
Document Manager is not opening it is showing some error message (see attached file) please give solution ASAP
Awaiting for your reply,
Madan
Do you have all the Service PAcks and Frameworks for AutoPLANT installed? Many times installing the 08.09.03.72 FW resolves these types of issues. If it is installed, you might want to consider running a repair on it from the Control Panel Add/Remove Programs interface.
Madan,
Looks like you are trying to launch Vison, not document manager... Is it possible you double clicked the wrong icon?
Vision requires a license, document manager does not.
If you are indeed launcing doc mgr, try going back in to project administrator and selecting the project you want to open, then close project admin and try again to open doc mgr.
Brian
