Color depending on raceway "status"
Hi All,
Is it possible when you draw a raceway, to make it appear in another color depending on the "status"?
For example, I want a cable tray that I draw with status pre-existing to appear blue instead of red.
And also I need the status future, and want all cable trays drawn in future to appear magenta.
Philipp
  • Hi Philipp,
    In BRCM the color of the raceway is based on the Level on which it is set (LV ,MV, CTRL ,COM).
    To have the color changed based on Status , You can try to change the color of the level assigned through level manager and while routing the cable tray , select the desired status and the desired level or the level assigned to the tray.
    Go to Attributes>> Manage.
    In the Level Manager that is displayed select the level of the cable tray desired and the color can be changed through the Level Manager.
    While routing the cable tray select the status , select the level and you can change the color of the level that the cable tray is assigned to through level manager in order to display the cable tray with color according to status.
    Hope this helps.
    Answer Verified By: Philipp Holenstein
