Hello, I have a problem with generating isomoetrics. When I open idgn to OP Iso Manager connect edition I see log: "OUT OF 1 MODELS, 1 MODELS FAILED TO LOAD OR WERE SKIPPED, DO YOU WANT TO SEE LOG?". PLESE SEND ME AN ANSWER.
Was able to genenrate Iso based on your DGN and default OpenPlantMetric workset. I have the same version of OPIM as you, 10.05.00.27. So most likely it's something to do with your workset customisation or isometric style.
G1-Płyn-1810l-spectest-iso-1-spl-1.dgn
Thanks Tuan,
I think this isnt problem with workset customisation or isometric style because it wasnt codified after instalation, I instaled the lastest wersion yesterday like printscreen as posted above. What do You think , maybe it is problem with RAM random acces memeory? The Open Plant requires minimum 16GB RAM but I have only 12 gb RAM.
Hi Marcin,
Could you please try to change the regional format settings Country as United States and English (United States) as below.Please do give it a try and let us know if that works .
Harshavardhan Kaduru
Harshavardhan K
Product Engineer I, Facilities Engineering
Answer Verified By: Harshavardhan Kaduru
Now its working, thanks Harshavardhan.
