Here want to set the new project in a difined folder.I want move the default workspace "C:\ProgramData\Bentley\BRCM CONNECT Edition\Configuration" to Z:\FoeEITCE\Configuration.And other people also can use this workspace together.How to change the .cfg files?
For the concern you can refer the below wiki link for deploying BRCM on local drive. Wikilink: "https://communities.bentley.com/products/electrical___instrumentation/w/electrical_and_instrumentation__wiki/45341/how-to-deploy-a-shared-workspace-in-brcm-connect-edition" Hope this wikilink helps regarding your concern.
Hi Long Jun Deng,It is not recommended to make change in msdir.cfg file in BRCM CONNECT Edition. The issue you are facing it might be due to msdir.cfg file. Or try to follow the steps as given in the wiki link below:Wiki Link: "https://communities.bentley.com/products/electrical___instrumentation/w/electrical_and_instrumentation__wiki/45341/how-to-deploy-a-shared-workspace-in-brcm-connect-edition"
Answer Verified By: Aadarsh Tale
