Hi everybody,
I was wondering if there is a possibility to place an Orifice Plate without the corresponding flange set.
For example if I want to place an orifice directly to an nozzle on a tank.
Also I would like to able to use the “normal” flanges of my specification when using an orifice plate, so that I do not have to keep track of both the normal flanges and the Orifice Flanges. I think it is nice to have the possibility to make them different from the normal flanges, but most of the time we do not need that feature, because the dimensions of the orifice flanges will just be the same as for the normal pipeline flanges.
I noticed that it is possible to place a flange set first and then delete one flange and one gasket. This helps a bit when placing an orifice to a “dumb” MicroStation equipment, but what I would like best would be the possibility to just place a normal flange, then adding an orifice plate to it (gasket between them gets placed automatically, like when I attach two flanges to one another).
Hello Florian,
Thanks for posting your concern to plant forum.Did you create a new class for Orifice Plate in schemas & want to place them manually?
or you want to place a Plate Flange without flange sets so that plate flange can be placed against any flanged component?
Regards | Deepak Singh
/cfs-file/__key/communityserver-discussions-components-files/5927/0638.ScreenCapture_5F00_15.01.2020-17.41.27.wmv
Currently using:
OpenPlant Modeler - Version: 10.09.00.74
[MicroStation - Version: 10.14.02.01]
