In OpenPlant Modeler - when I place a valve on a pipeline, I would like it to have the same Normal Operating Pressure value as my pipeline.
Anyone could help me with a hint how to do it? I am using OPM CE Update6
Thanks in advance!
Hi Michal,
Thank You for posting you query.
Please follow below Wiki articles for your reference:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/35276/to-cascade-pipeline-property-value-to-fasteners
https://communities.bentley.com/products/plant/m/plant_design_and_engineering_files/273472
Let us know if this helps
Harshavardhan K
Product Engineer I, Facilities Engineering
Answer Verified By: MichalSz
Hi Harshavardhan,
Thank you for a quick reply!
Well I understand that I need to use Calculated ECProperty Specification custom attribute and this is the part that is clear to me, however when it comes to ECExpression: this.GetRelatedInstance("SEGMENT_HAS_PIPING_COMPONENT:1:PIPING_NETWORK_SEGMENT").GetRelatedInstance("PIPELINE_HAS_SEGMENT:1:PIPING_NETWORK_SYSTEM").NUMBER
I dont know how to modify it to make it work in my case. Could you give me any hint on this, please?
With the help of your Wiki articles I managed to find a solution for my concern. Thanks again.
Hello Michal,
In addition to above thread, you can refer below wiki article that explain your requirement.
Regards | Deepak Singh
