HI Everyone,IS there a way to stop OPM from refreshing all the child piping component property while making changes to any property of that particular line.Ideally if it can be a choice of when it would refresh or not that would be perfect.We need to have exactly reverse result of what highlighted in below wiki,https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/34912/how-to-update-pipeline-tag-name-or-component-property-after-any-changes-in-schema.
Regards,Vivek
Hi Vivek,
You can try with variable below which is primarily for INSULATION property if you are looking for it.
OPM_PM_UPDATE_INSULATION_ON_COMPONENTS=0
However it should work in specific version of v8i 327.
We can have a call to discuss it further.
HTH,
Rahul Kumar
