Hi All
In which design file is it possible to import I-Models (e.g. equipments, raceway etc.) ?
BRCM connect
Thanks in advance and Regards
Philipp
Hi Philipp,You can import I-Model files file in the Equipment design file in Bentley Raceway and Cable Management CONNECT Edition.Thanks and Regards,Gaurav Mehesare
Thanks i can press the iModel import button, and it asks me the type of the file. But not the file location ?
Hi Philipp,If the model is created using the Bentley Substation application then you need to select Substation\promis.e (Electrical schema) option and the alternative I-Model Import is possible with OpenPlant Modeler.Thanks & Regards,Gaurav Mehesare
Hi Philipp,I would like to add one more point is that the I-Model file should be attached as 1st reference in the Reference Manager. Hope this will helps.Regards,Gaurav Mehesare
Answer Verified By: Philipp Holenstein
Hi Philipp,You can also follow the below WIKI link to know the actual workflow for "How to import data from I-model file in Bentley Raceway and Cable Management"WIKI Link: https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/47170/how-to-import-data-from-i-model-file-in-the-bentley-raceway-and-cable-management-connect-editionRegards,Gaurav Mehesare
