Hello Gents
I wonder how to quick copy schema in class editor to another projects? For example I have all setups in under Support Class, however I want the same settings of Support to another on going projects.
is there any efficient way? Like export and import overwrite? see the picture below
Hi You,
Thank you for posting a query on Bentley Plant Forum.
You could use the Schema Differencing tool which is a sub utility of Class Editor for this purpose.
It compares two schemas and displays a set of missing, added and modified instances and you could append these in one schema or another.
If you have uniform modifications for all the schemas then you could copy and paste the same schemas and use in different worksets.
Hope This Helps!
Regards,Swapnil Joshi
Hi Sir
I tried that, however I got an error as shown picture below, any idea?
Thank you for getting back to us.
There is a wiki article that you can go through to accomplish this requirement.
Class Editor Schema Differencing and Supplementing Applies To Product(s): Bentley Class Editor Version(s): Environment: Windows 7/8.1/10( 64 bit) Area: Class Editor Subarea: Schema Differencing Original Author… Last edited over 7 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki 1 comment
Hope this helps.
Regards | Swapnil Joshi
