I have need to make an DN25 with offset within 30 mm, rough sketch is found below.
Is it possible to add the offset to some existing flange in my spec if I just manually change some part dimension by MS Access? What would be the correct variable?
BR
Tuomas
Hello Tuomas,
Thanks for posting your query to Bentley Plant forum, based on provided image it seems that you want to place some sort of multi stage valve. Did you try placement of Air Stage Valve in OpenPlant Modeler?
How many such components needs to be placed in model file? Can't we use custom component for placement of such components in OpenPlant Modeler? Below wiki article gives an idea about custom component placement in OpenPlant Modeler.
ThanksRegards | Deepak Singh
No, I have a need to place an existing globe valve to new pipeline and this valve has little bit not so common dimensions. I was just just wondering that if there was an easy solution to adapt offset to valve inlet and outlet.
Example of valve can be found below.
