Is there a way to filter Questions/Discussions based on a particular tool. I would like to be able to focus my attention on items for Bentley Raceway and Cable Management.
Hello Eric,Thanks for highlighting this feature.Currently, there is no feature that enables to search based on particular tool.
We will be discussing this with the Communities Site Administrator for this and see if any filter can be added or a setting can be made available.Regards,Lalitesh Vaidyar
Thanks for looking into this!
Hi Eric, currently there is only one forum serving all of the Bentley Plant product line. So, if you subscribe to this forum, you will receive alerts for all posts, regardless of the product. The product that a forum post pertains to is based on the free text that the user enters in the title and description (no dropdown field to select the product), so there is no way to accurately delineate which product a post is for, to facilitate a method to choose which product you want to be alerted on.
If you are only interested in BRCM, here are a few quick ideas:
1) Set up an RSS based on the BRCM tag. For example https://communities.bentley.com/searchrss?tags=BRCM The downside to this is that it relies on the user properly tagging their posts.
2) Subscribe to this forum, and set up a rule in Outlook (or other email application, if available) to send emails from the @communities.bentley.com domain to a folder if the subject or body contains BRCM, and delete others from that domain if they do not.
