When I place a directional anchor on a tee shoe it offsets south instead of being at the origin of the support. See screenshot looking from the top view.
This does not happen with the directional anchor on pipe.
Any ideas or will a ticket have to be filed?
Dan
Hello Dan,
Thank you for posting your query on Bentley Communities Forum.
we will check this issue in AutoPLANT Modeler CE Update 1 and provide you the update.
you are testing this issue in which version of AutoPLANT Modeler ?
Please confirm..
Regards Abhijeet Shinde
10.01.00.67
Verified with APMCE U1, directional support guide working fine.
seems project specific concern. Could you please check with out of box project and update me result.
Looking forward to your reply.
Abhijit Bute
Hello Abhijit. Please try the directional anchor support as requested. You have confirmed the guide works.
1000 \\WORK\\L100.DWG1001 MMETRIC 1011 OOTBMMACCESS 1004 \\WORK\\BORDER.DWG1005 0 11024 3.141028 AutoPLANT1029 8.9.32100 AT_PIPE 2101 Base 2108 PIPE 2109 425654071DB87A14C3FDE5F557E91F6CF4DBDF21 2105 12040 6 2041 168.2752022 28.2272023 0.0002058 AA 2050 Mmcs150 2051 40 2053 630P10012054 PIP6 2055 PIPE, SCH 402056 PIPE 2059 ASME/ANSI B36.10 2064 12065 172067 PIPE 2069 02170 AREA2171 6302170 UNIT2171 10002170 SERVICE2171 P2170 SPOOL2171 P2006 AT_K9SII3BM_1 3000 4.141394 9.326225 0.000000 3002 6 3003 168.2753007 103009 PL3012 40 3020 2004.141394 9.326225 0.000000 3022 6 3027 203029 PL3032 40 2100 AT_SUPPORT_TEESHOE 2101 BASE 2105 22106 12023 0.0002058 AA 2050 Mmcs150 2053 630P10012054 SUPTS-6 2055 TEE SHOE SUPPORT2056 SUPPORT 2063 S1-1-A 2064 02065 02069 02170 AREA2171 6302170 UNIT2171 10002170 SERVICE2171 P2170 SPOOL2171 P2006 AT_K9SII3BM_3 2040 6 2041 168.2752133 100.0002135 300.0002136 1.5632137 100.0002141 1 0 02142 0 0 -13000 1004.141394 9.326225 0.000000 3020 1004.141394 9.326225 -84.137500 3040 1004.141394 9.326225 -184.137500 2100 AT_SUPPORT_SABOXES 2101 BASE 2105 32106 22023 0.0002058 AA 2050 Mmcs150 2053 630P10012054 SUPAB-6 2055 DIRECTIONAL SUPPORT ANCHOR BOXES2056 ANCHOR 2063 DA4 2064 02065 02069 02170 AREA2171 6302170 UNIT2171 10002170 SERVICE2171 P2170 SPOOL2171 P2006 AT_K9SII3BM_5 2040 6 2133 80.0002141 0 0 -12142 0 1 03000 1004.141394 9.326225 -100.000000 3020 1004.141394 89.326225 -184.137500 3040 1004.141394 -40.673775 -184.137500 2181 100.0002183 50.0002184 50.0002185 50.0002144 0 0 0
