Is it possible to create a custom date format for use in Isometrics.
We have a client border that needs dd.mm.yy
Hello Bear,
Thanks for posting your query to Bentley Plant forum,
Are you trying to achieve this result in OpenPlant Isometrics V8i or for CONNECT?In CONNECT we have possible flexibility to achieve such date format.
Regards | Deepak Singh
V8i.
Anyone able to help on this?
Hi Sean,
We are in discussion with Development team. Like mentioned earlier, few post processing method can help here.
I hope we shall share the result by today.
HTH,
Rahul Kumar
For anyone following, this is what we ended up with as a solution:
Please follow below mentioned steps to achieve desired result:
2. Use a pre/postprocessing hook to change this int the intermediate file itself to dd.mm.yy like this
TEXTNODES
FILENAME dummy-0--mEX-OPM-iso-1
STYLE IFC
DATE 14.05.20
TIME 12:50:41
3. For this we need the following in the [0100] section of the isometric
; Called before the intermediate file is interpreted
; Basic use is to augment/change the intermediate file
[0100]
RUN = $(IE_CONF)date.bat
4. Generate Iso output thereafter, you will get the desired result as shown below.
