Is it possible to publish config variable results to a field in an Isometric?
Hi Sean,
this is in discussion with dev team. Will update shortly on this.
HTH,
Rahul Kumar
Any feedback Rahul?
Rahul has this taken up internally already, we will get back to you soon enough as he receives an input on that.We will make sure we keep you no longer waiting.
Regards | Soham Mhaskar.
Don't worry about it Soham, I worked it out using the textnodes.txt file with the nodes2da.txt file.
I've closed the SR.
