Navigator V8i Compatibility With PW 10.00.03.280
HI Everyone,
We are planning to move to PW client/server 10.00.03.280 , Is this version compatible with Microstation 08.11.09.829, OpenPlant V8i 08.11.11.327 , OPIM 08.11.11.294 and Navigator 08.11.09.713 ??
I am able to browse to PW once opened from desktop and it is fetching all related documents referenced in it, For Microstation V8i it allows attribute exchange as well,
But for some reason these two links below saying it not compatible,
(1) https://docs.bentley.com/LiveContent/web/ProjectWise%20Version%20Support%20Matrix-v1/en/GUID-1A2E193F-C3D9-4709-92A2-E5B9301B5946.html
(2) https://app.powerbi.com/view?r=eyJrIjoiOTViOTExNTYtOWUwNS00ZWNmLTliMjYtYzU0OWY5ZmZhYmM0IiwidCI6IjA2N2U5NjMyLWVhNGMtNGVkOS05ZTZkLWUyOTQ5NTZlMjg0YiIsImMiOjF9
I am trying to find If is this link data needs to be updated OR which area in V8i version mention above is not compatible, as I am able to work most common part with PW client/server 10.00.03.280.
Vivek
Parents Reply
  • Thanks Ashutosh,
    Yes OPM is priority built, but if it is supporting OPIM , then I think it is covering OPM as well, looking forward for your update.
    For us most critical one is Navigator V8i , as Bentley might have reached to end of product development but for us it's a end of the road.Currently Bentley connect family do not offer solution to replace Navigator V8i with it's full functionality.
    Closest one is "Bentley Connect View" , which is a free viewer so it is not supporting clip volume, add references or saved view as Navigator does.
    I am hoping Navigator V8i should be kept supported until there is a better alternative.
    Thanks again Ashutosh your input helps a lot.
    Vivek
