Hi All,
I need to change the unit settings to millimeters, I know that BRCM is by default set to meters.
Where can I change this?
Thanks in advance
Philipp
Hello Philip,
You can change the design file settings from the backstage: Follow the path FIle>Settings>File>Design File Settings.
Please make sure that you are keeping the same master unit for all the design files like Raceway, Equipment and Routing to route the cables successfully.Thanks
Answer Verified By: Philipp Holenstein
