HI ,Is there any product available from Bentley which can take off attributes value of all piping component to a database Access or SQL ??,And can update value back from database to 3D model ?? Something similar to model server but without checking in component , Our requirement is to keep plant model file based.
Regards,Vivek
Hi Vivek,
Meanwhile, would it be fine if you can extract report by pipeline and add all properties, export it to excel and then you can use latest feature of OpenPlant Modeler to import Tag data using excel?
can you send some attribute sample which we try to export and import?
-Regards | Rahul Kumar
Rahul Kumar
HI Rahul,
Is there a way to export tags first, to import it afterwards with changes,
Like we do in ProjectWise , we export attribute first and modify it to import afterwards.
I am thinking about changing piping component attributes of an existing model, if it is an option?
