Hello Everybody,
We trying to follow a couple of Wikis for OPM Connect Edition (7) e.g. "How To Add New Property and Define A Calculated Formulae in that Property" or "How to Display Elevation Differences using EC Annotation in OpenPlant Modeler", but for the ECExpression I am not able to add required ECExpression SymbolSets, like it is described in the article.
I have no options to add. Please see attached a picture of the Calculated ECProperty Spec. in OPM CE (7):
Like it is described in the article (probably for v8i):
Any concerns, what to do, or to add?
Hello Martin,
Thank You for posting your in Bentley Forum . I would like to mention this can be done by copying custom attribute from different property and pasting in the property you are trying to work with. However, please allow us some time so that we can get you the exact property name in Connect Edition Class Editor.As a workaround , we request you to use V8i Class Editor and load the same set of schema and add Required ECExpression SymbolSets .
Harshavardhan K
Product Engineer I, Facilities Engineering
HI Harshavardhan,Any update for this question ?? Now we are at update 8, sounds like it's same situationRegards,Vivek
