Win10
OPM Upd7
Have various connection issues when trying to produce Iso's
Is there a way to select a component by GUID
A typical error message from production log
[20.08.2020 09:11:24] Pre-processing: Convert EC to Isometric Dataset------------------------------------------------------------------------------------------------------------------------ Error: Connectivity Failed Pipe[PIPE]bbf4999d-78aa-40b1-a8b5-2578aa403d42 Unconnected Components at Bentley.Isometrics.Converter.Connectivity.FillDataset(IsometricDataset ds) at Bentley.Isometrics.Converter.DataProcessor.ProcessDataset(IsometricDataset dsData) at Bentley.Isometrics.Converter.DatasetManager.GetDataset(ECInstanceList ecData, IECKey RootClassKey, String IsometricName, RepositoryConnection connection) Error:Unconnected Components
With these types of errors, typically IsoMetricManager will Crash
By the way:
All connectivity checks are ok
You can go for an Advanced Search in Explorer > OpenPlant Modeler-section.
In "Search For:" pick appropriate class (here "Pipe"), where GUID equals to bbf4999d-78aa-40b1-a8b5-2578aa403d42
Answer Verified By: Rahul Kumar
Thx
Missed it
Hi Peter,
I think we also had a further discussion, related to Isometric Concern and like suggested you have SR for similar issue. we will have it investigated.
HTH,
Rahul Kumar
Answer Verified By: Peter Sande
