Hi guys. I need help. Сan't find library Bentley.MstnPlatformNET.InteropService.dll. Where to get it?
Hi Ivan
Thanks for contacting Bentley Plant forum!
can you please share more information on dll that you are looking for?
HTH,
Rahul Kumar
We are new in Bentley coding. We have to create a user component from a fragment(cell). We use an example in wich used library Bentley.MstnPlatformNET.InteropServices. We can't find it.
Can you please elaborate more? Are you in CONNECT OP or V8i OP? Are you using Microstation SDK or OpenPlantSDK from CONNECT?
Where are you getting this code from? I searched my code and i have references for Bentley.MicroStation.InteropServices but i couldnt find any references to Bentley.MstnPlatformNET.InteropService.
Can you provide details?
thansk,
Ok i found it. I was confused because you mentioned the DLL. This is not a dll and its a namespace in the Bentley.Microstation.dll.
The location of the dll is
C:\Program Files\Bentley\OpenPlant CONNECT Edition\OpenPlantModeler\Assemblies\Bentley.MicroStation.dll
Please check the snapshot below.
Answer Verified By: Ivan Chirich
