Is there any way I can import Bentley Raceway and Cable Management into AutoDesk Revit?Currently, I am able to export DWG file in Revit but parametric data associated with 3d Geometry is not visible their?
Hello Robin,
Thanks for posting your query to Bentley Communities.
If you want to export Bentley Raceway and Cable Management DGN file to some other formats, these are available options:Have you tried with any of these for example .dxfHTHRegardsVikrant kale
Thank you for reaching out to us on forum.You can check the supported file types of the Autodesk Revit and also refer the "Importing CAD Files" section on the Autodesk Knowledge Network for the help.
Would you please share some more details with us like what is the idea behind importing BRCM files in Revit, is there any issue you are facing while using BRCM.
Regards,Aadarsh Tale
@aadarsh Tale thanks for the prompt reply actually one of our BIM project we are using Autodesk Revit and for our cable design we are using BRCM although somehow we manage to import 3d Geometry using dwg format into Revit but parametric data associated with 3d Geometry is not coming in Revit?
Hi Robin,
I believe that after the import from BRCM to Revit, the design files losses its intelligence and you may experience it with all the designs from non Revit applications. I think you will not be able to use the Parametric data inside Revit and have to recreate it there, you can have more details on this from the Autodesk team.
Hope this helps.
Answer Verified By: Aadarsh Tale
