We have an issue when creating and then trying to generate Iso for newly created sheet. More than often we get the message 'Error in fetching data' (See attached image)
If closing isometric manager and then generating same from Pipeline Manager it works.. Why does this happen?
Hello Peter,
Thanks for posting again on Bentley Plant Forum.
I am not able to reproduce it at my end for the moment. Although I think I have seen such an error message before.Let me have this taken up internally with the Team and get back to you.Regards | Soham Mhaskar.
Has this issue been looked at, I have started getting it since an auto update to windows 11. It was working well before the update.
Do you have this issue with other styles too or with the custom style only?As a possible check, If it is with custom and external db is used with it, try to use the xls instead of xlsx.However still need to be checked in details for the issue, it could be due to multiple reasons. Another observed reason is for ISO_SHEET class Name property the Calculated EC Expression have lot of GetRelatedInstance. If it is so, you can created custom property at ISO_SHEET class include GetRelated EC Expression to them and for NAME property use them directly like this.CUSTOM_PROPERTY
