I have several P&IDs that have some unused services. How can I delete them?
Best regards,
Edgar
Unfortunately there is no simpler way. OPPID has intentionally restricted the deletion of Project Objects from the OPPID interface. We can better manage these things from PlantSight Datamanager in coming releases. For now, you can dump all the schemas in OPPID in a local folder say d:\PIDSchemas\ and in Microstation point your MS_ECFRAMEWORKSCHEMAS variable to this folder. After this, if you open this in Microstation, it will show the Items in Microstation's explorer and there you can right click and delete these items,
HTH,
Ok, thank you. I will try and update.
