CUSTOM COMPONENT CAN'T BE PLACE FLANGE
HELLO,I CREATED NEW CUSTOM COMPONENT FOR FLOW METER AND FOLLOW THE STEPS BELOW:
1.Click Define Origin to define the origin point of the component.
2.Define the connect points for both the ports. Click Define connect points and select the left port of the valve followed by defining the direction. As soon as MAIN_PORT is defined it asks to define the RUN_PORT.       Similarly, select the right port and define the direction by moving the cursor towards right.
3.Once the Origin & Connect points are defined Create Component button is enabled automatically. Click Create Component to finish the component creation.
4.It opens up the component placement dialog. Fill in the required fields and click the Green Check button to complete the placement of component.
BUT WHEN I PLACE FLANGE TO FLOW METER,JUST ONE END CAN BE PLACE LIKE PICTURE.
