Dear Guys,
I have Autoplant SS3 Project package (.zip) with me, and I am trying to unpackage the project with using oracle 12 c.
Whenever i try, i am getting error like, the packager prompting to exit. ???
The same package is working with MS Access / SQL. I am sure its related to ORACLE.
But i am not clear in this, Could you help me in this section ???
Ananthakumar M
Hi Ananthkumar,
Can you confirm which version of AutoPLANT Modeler you are trying to unpackage with Oracle 12 C? There could be compatibility issue but we need to understand your overall expectation.
RegardsRajesh Agrawal
I have installed Autoplant SS 8, and Open plant SS6,
AP : apm64081114124en.exe
OP : oppid081111319en.exe
version="8.11.14.124" (found from RebCompDlgs.dll)
Our Expectation is :
1. Unwrap the package with supporting Oracle db
2. Upgrade from SS3 to SS8
During the unwrapping methods,
After selected ORACLE as the last step of unwrapping the below attached image (second image) is popping out instead of the third image,
First image
Second Image
Third Image
Thanks and regards
Ananthakumar
Dear Team,
Did you find any solution for this ?
Please help us to upgrade the project..
Ananth
