Any way to show the fields in a catalog table in alphabetical order?
Best regards,
Tuan
Hi Tuan,
Thank You for posting Bentley Forum. Would you be able to send us the snap to let us understand which are these column you want to sort and if we have that option to sort ?
Harshavardhan K
Product Engineer I, Facilities Engineering
Hi Harshavardhan,
Snapshot of the Ansi-asme.mdb metric catalog shipped with U8. I would like have the fields in alphabetical order from left to right. Some table can have quite a few fields and it can get tricky to navigate.
best regards,
I just checked and seems like if you want to sort the field list and it needs to done manually by moving . Pick with the help of mouse and drop next to one column.
Ok. But doing doesn't save the layout. Up on reopening the catalog, the columns go back to their original layout.
Tuan,
If that's the case we will have to look into it , in what what way it can saved and to retain the same order.
that would be great. Thanks Harshavardhan.
